ujilyellow
PC Specification: i5 3470, r9 380 4gb , windows 10
motion2 disable on 1440p video
Thu Jun 23, 2016 5:45 am
i have no idea, if my graphic card not support or splash app not support video with resolution 1440p.
video playing without motion2. come on mirilis, please fix this.
jscoys
PC Specification: Windows 10
Re: motion2 disable on 1440p video
Sun Jun 26, 2016 11:18 pm
ujilyellow wrote:i have no idea, if my graphic card not support or splash app not support video with resolution 1440p.
What's your pc specs?
ujilyellow
Sun Jun 26, 2016 11:55 pm
Marsianin
PC Specification: Core i7 965, 12Gb, 2xGTX280, Win7 x64
Sat Jul 16, 2016 7:44 am
Same thing here. 4k videos on Splash 2 shows without motion2. The switch is on to max but video is not smooth.
i7-5960X / 32Gb RAM / SSD RAID / 2 x GTX980 in SLI so it's definitely not my system.
My videos are mp4 H.264/AVC 3840x2160 up to ~30Mbps, 23-25fps. Most of them 10-15Mbps.
40 different video clips. Never seen motion2 working on them.
Windows 10 Pro / Splash Pro 2.0.4
Return to “Splash 2.0”
