schoolruler
PC Specification: Windows 10
Remote Action over the internet
Sat Jun 25, 2016 9:18 pm
I recently got a copy of action! and I'm loving it. When I use the remote action feature everything works fine while on the same network, but if I try to access it from outside my home network it only sends 200 Kbits per second of data. Already tried restarting the remote action app and action desktop program, but I just don't know what to do.
I also followed the tutorial for troubleshooting signal and bandwidth issues. I lowered the resolution to 480p, max bitrate of 1 Mbps, and a video framerate of 15. These setting work at home, but not from another network or mobile.
If I can get this to work then I will have found the program of my dreams, so I will be eternally grateful if anyone can help me. :mrgreen:
Grantpag
PC Specification: windows 7
Sat Nov 28, 2020 3:44 am
is there anyway to use remote action without need auth the pc that you want to stream your pc too it?
i have try to use it but it need to auth the second pc on my main pc but if im not in my house its a little bit hard to do :/
Return to “Monflo - Remote PC Access and Gaming”
