imhulksog
PC Specification: GTX 970 i5-6400
Action! crashing Java ( Minecraft)
Wed Jun 29, 2016 2:13 pm
Hello
My action worked fine untill one day it started to crash my minecraft. I hate it because now I cant record at all!
Im using the newest version of action! action_1_31_3_
My specs: http://prntscr.com/bmlr6o
The message I got from minecraft:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff7e829de40, pid=6116, tid=9184
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C 0x00007ff7e829de40
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000017c1e000): JavaThread "Thread-7" [_thread_in_native, id=9184, stack(0x0000000027010000,0x0000000027110000)]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x0000000000000008 0x00007ff7e829de40
Registers:
RAX=0x000000001b910940, RBX=0x000000001d489870, RCX=0xffffffffb7010ced, RDX=0x000000002710ed08
RSP=0x000000002710ec78, RBP=0x000000002710ece8, RSI=0x0000000000000188, RDI=0x0000000000002bf5
R8 =0x0000000000000042, R9 =0x00000000c9208718, R10=0x0000000000000132, R11=0x000000005e6e5300
R12=0x0000000000000000, R13=0x000000001d489868, R14=0x000000002710ed08, R15=0x0000000017c1e000
RIP=0x00007ff7e829de40, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x000000002710ec78)
0x000000002710ec78: 0000000002885b74 000000002710ece8
0x000000002710ec88: 00000000028777b0 00000000c9208718
0x000000002710ec98: 0000000000000011 0000000000000000
0x000000002710eca8: 000000002710eca8 0000000000000000
0x000000002710ecb8: 000000002710ed08 000000001d48a150
0x000000002710ecc8: 0000000000000000 000000001d489870
0x000000002710ecd8: 0000000000000000 000000002710ed08
0x000000002710ece8: 000000002710ed60 0000000002877a2d
0x000000002710ecf8: 00000000cd1de690 000000000287f6b8
0x000000002710ed08: 00000000c9208718 0000003f92a84e11
0x000000002710ed18: 00000000cd439ff0 000000002710ed10
0x000000002710ed28: 000000001d489753 000000002710eda0
0x000000002710ed38: 000000001d48a150 0000000000000000
0x000000002710ed48: 000000001d4897e0 000000002710ed08
0x000000002710ed58: 000000002710eda0 000000002710ede8
0x000000002710ed68: 0000000002877a72 0000000000000000
Instructions: (pc=0x00007ff7e829de40)
0x00007ff7e829de20:
[error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xc0000005]
Register to memory mapping:
RAX=0x000000001b910940 is an unknown value
RBX={method} {0x000000001d489878} 'nSwapBuffers' '(Ljava/nio/ByteBuffer;)V' in 'org/lwjgl/opengl/WindowsContextImplementation'
RCX=0xffffffffb7010ced is an unknown value
RDX=0x000000002710ed08 is pointing into the stack for thread: 0x0000000017c1e000
RSP=0x000000002710ec78 is pointing into the stack for thread: 0x0000000017c1e000
RBP=0x000000002710ece8 is pointing into the stack for thread: 0x0000000017c1e000
RSI=0x0000000000000188 is an unknown value
RDI=0x0000000000002bf5 is an unknown value
R8 =0x0000000000000042 is an unknown value
R9 =0x00000000c9208718 is an oop
java.nio.DirectByteBuffer
- klass: 'java/nio/DirectByteBuffer'
R10=0x0000000000000132 is an unknown value
R11=0x000000005e6e5300 is an unknown value
R12=0x0000000000000000 is an unknown value
R13=0x000000001d489868 is pointing into metadata
R14=0x000000002710ed08 is pointing into the stack for thread: 0x0000000017c1e000
R15=0x0000000017c1e000 is a thread
Stack: [0x0000000027010000,0x0000000027110000], sp=0x000000002710ec78, free space=1019k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.WindowsContextImplementation.nSwapBuffers(Ljava/nio/ByteBuffer;)V+0
j org.lwjgl.opengl.WindowsContextImplementation.swapBuffers()V+35
j org.lwjgl.opengl.ContextGL.swapBuffers()V+3
j org.lwjgl.opengl.DrawableGL.swapBuffers()V+0
j org.lwjgl.opengl.Display.swapBuffers()V+39
j org.lwjgl.opengl.Display.update(Z)V+44
j org.lwjgl.opengl.Display.update()V+1
j cpw.mods.fml.client.SplashProgress$3.run()V+632
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x0000000017c1e000 JavaThread "Thread-7" [_thread_in_native, id=9184, stack(0x0000000027010000,0x0000000027110000)]
0x0000000019f69800 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=5272, stack(0x0000000024e20000,0x0000000024f20000)]
0x0000000019fac800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=6636, stack(0x000000001d750000,0x000000001d850000)]
0x000000001b1d7800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=8344, stack(0x000000001bee0000,0x000000001bfe0000)]
0x000000001ab19800 JavaThread "Snooper Timer" daemon [_thread_blocked, id=5848, stack(0x000000001bde0000,0x000000001bee0000)]
0x0000000016ecb000 JavaThread "Service Thread" daemon [_thread_blocked, id=5660, stack(0x00000000172a0000,0x00000000173a0000)]
0x0000000016544800 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=9532, stack(0x0000000016da0000,0x0000000016ea0000)]
0x000000001653f800 JavaThread "C2 CompilerThread1" daemon [_thread_in_native, id=5840, stack(0x0000000016ca0000,0x0000000016da0000)]
0x000000001653c800 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=5192, stack(0x0000000016ba0000,0x0000000016ca0000)]
0x0000000016539000 JavaThread "Attach Listener" daemon [_thread_blocked, id=9692, stack(0x0000000016aa0000,0x0000000016ba0000)]
0x0000000016538000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=10172, stack(0x00000000169a0000,0x0000000016aa0000)]
0x0000000016537000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=2232, stack(0x00000000168a0000,0x00000000169a0000)]
0x00000000164fd800 JavaThread "Finalizer" daemon [_thread_blocked, id=5100, stack(0x00000000167a0000,0x00000000168a0000)]
0x00000000164f6000 JavaThread "Reference Handler" daemon [_thread_blocked, id=5216, stack(0x00000000166a0000,0x00000000167a0000)]
0x0000000002774000 JavaThread "Client thread" [_thread_in_Java, id=1104, stack(0x0000000002670000,0x0000000002770000)]
Other Threads:
0x00000000164ee800 VMThread [stack: 0x00000000165a0000,0x00000000166a0000] [id=6620]
0x0000000016ecc800 WatcherThread [stack: 0x00000000173a0000,0x00000000174a0000] [id=6772]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
par new generation total 118016K, used 92174K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 75% used [0x00000000c0000000, 0x00000000c4d43990, 0x00000000c6680000)
from space 13056K, 100% used [0x00000000c6680000, 0x00000000c7340000, 0x00000000c7340000)
to space 13056K, 0% used [0x00000000c7340000, 0x00000000c7340000, 0x00000000c8000000)
concurrent mark-sweep generation total 195348K, used 117208K [0x00000000c8000000, 0x00000000d3ec5000, 0x0000000100000000)
Metaspace used 27295K, capacity 27504K, committed 27776K, reserved 1073152K
class space used 3268K, capacity 3340K, committed 3456K, reserved 1048576K
Card table byte_map: [0x0000000012030000,0x0000000012240000] byte_map_base: 0x0000000011a30000
Marking Bits: (CMSBitMap*) 0x00000000027ccf08
Bits: [0x0000000012850000, 0x0000000013650000)
Mod Union Table: (CMSBitMap*) 0x00000000027ccfc8
Bits: [0x00000000025a0000, 0x00000000025d8000)
Polling page: 0x0000000002570000
CodeCache: size=245760Kb used=11062Kb max_used=11618Kb free=234697Kb
bounds [0x0000000002870000, 0x0000000003470000, 0x0000000011870000]
total_blobs=3531 nmethods=2897 adapters=547
compilation: enabled
Compilation events (10 events):
Event: 6.407 Thread 0x0000000016544800 3473 2 java.util.Formatter$FixedString::<init> (15 bytes)
Event: 6.407 Thread 0x0000000016544800 nmethod 3473 0x0000000002c84d90 code [0x0000000002c84ee0, 0x0000000002c85050]
Event: 6.407 Thread 0x0000000016544800 3474 2 java.util.Formatter$FixedString::index (3 bytes)
Event: 6.407 Thread 0x0000000016544800 nmethod 3474 0x0000000002c84a90 code [0x0000000002c84be0, 0x0000000002c84d30]
Event: 6.407 Thread 0x0000000016544800 3475 2 java.util.Formatter$FixedString::print (18 bytes)
Event: 6.407 Thread 0x0000000016544800 nmethod 3475 0x0000000002c846d0 code [0x0000000002c84840, 0x0000000002c849c8]
Event: 6.411 Thread 0x0000000016544800 3477 1 java.awt.image.ColorModel::getNumComponents (5 bytes)
Event: 6.412 Thread 0x0000000016544800 nmethod 3477 0x0000000002c84010 code [0x0000000002c84160, 0x0000000002c84270]
Event: 6.415 Thread 0x0000000016544800 3478 2 java.util.Date::<init> (10 bytes)
Event: 6.415 Thread 0x0000000016544800 nmethod 3478 0x0000000002f67f50 code [0x0000000002f680a0, 0x0000000002f681f0]
GC Heap History (10 events):
Event: 3.801 GC heap before
{Heap before GC invocations=7 (full 2):
par new generation total 118016K, used 115420K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 100% used [0x00000000c0000000, 0x00000000c6680000, 0x00000000c6680000)
from space 13056K, 80% used [0x00000000c7340000, 0x00000000c7d77118, 0x00000000c8000000)
to space 13056K, 0% used [0x00000000c6680000, 0x00000000c6680000, 0x00000000c7340000)
concurrent mark-sweep generation total 58184K, used 43617K [0x00000000c8000000, 0x00000000cb8d2000, 0x0000000100000000)
Metaspace used 21616K, capacity 21833K, committed 22016K, reserved 1069056K
class space used 2687K, capacity 2726K, committed 2816K, reserved 1048576K
Event: 3.808 GC heap after
Heap after GC invocations=8 (full 2):
par new generation total 118016K, used 13055K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 0% used [0x00000000c0000000, 0x00000000c0000000, 0x00000000c6680000)
from space 13056K, 99% used [0x00000000c6680000, 0x00000000c733ffa8, 0x00000000c7340000)
concurrent mark-sweep generation total 58184K, used 46104K [0x00000000c8000000, 0x00000000cb8d2000, 0x0000000100000000)
Event: 4.050 GC heap before
{Heap before GC invocations=8 (full 2):
par new generation total 118016K, used 118015K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
concurrent mark-sweep generation total 65948K, used 39566K [0x00000000c8000000, 0x00000000cc067000, 0x0000000100000000)
Metaspace used 22482K, capacity 22697K, committed 22912K, reserved 1069056K
class space used 2777K, capacity 2822K, committed 2944K, reserved 1048576K
Event: 4.058 GC heap after
Heap after GC invocations=9 (full 2):
par new generation total 118016K, used 11103K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 85% used [0x00000000c7340000, 0x00000000c7e17d20, 0x00000000c8000000)
concurrent mark-sweep generation total 65948K, used 44232K [0x00000000c8000000, 0x00000000cc067000, 0x0000000100000000)
Event: 4.981 GC heap before
{Heap before GC invocations=9 (full 2):
par new generation total 118016K, used 116063K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Metaspace used 25732K, capacity 25872K, committed 26240K, reserved 1073152K
class space used 3069K, capacity 3116K, committed 3200K, reserved 1048576K
Event: 4.986 GC heap after
Heap after GC invocations=10 (full 2):
par new generation total 118016K, used 11339K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 86% used [0x00000000c6680000, 0x00000000c7192f78, 0x00000000c7340000)
Event: 5.722 GC heap before
{Heap before GC invocations=10 (full 3):
par new generation total 118016K, used 116299K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Metaspace used 26288K, capacity 26448K, committed 26752K, reserved 1073152K
class space used 3136K, capacity 3180K, committed 3200K, reserved 1048576K
Event: 5.737 GC heap after
Heap after GC invocations=11 (full 3):
par new generation total 118016K, used 13056K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 100% used [0x00000000c7340000, 0x00000000c8000000, 0x00000000c8000000)
concurrent mark-sweep generation total 83712K, used 80282K [0x00000000c8000000, 0x00000000cd1c0000, 0x0000000100000000)
Event: 6.236 GC heap before
{Heap before GC invocations=11 (full 3):
par new generation total 118016K, used 118016K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Metaspace used 26644K, capacity 26832K, committed 27136K, reserved 1073152K
class space used 3186K, capacity 3244K, committed 3328K, reserved 1048576K
Event: 6.250 GC heap after
Heap after GC invocations=12 (full 3):
concurrent mark-sweep generation total 121428K, used 117712K [0x00000000c8000000, 0x00000000cf695000, 0x0000000100000000)
Deoptimization events (10 events):
Event: 4.283 Thread 0x0000000002774000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000002c85168 method=java.util.zip.InflaterInputStream.read([BII)I @ 100
Event: 5.165 Thread 0x0000000002774000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x00000000029f8ed8 method=java.lang.StringCoding$StringDecoder.decode([BII)[C @ 48
Event: 5.199 Thread 0x0000000002774000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000002de1564 method=java.util.Hashtable.addEntry(ILjava/lang/Object;Ljava/lang/Object;I)V @ 38
Event: 5.206 Thread 0x0000000002774000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x00000000029f8ed8 method=java.lang.StringCoding$StringDecoder.decode([BII)[C @ 48
Event: 5.299 Thread 0x0000000002774000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000002de1564 method=java.util.Hashtable.addEntry(ILjava/lang/Object;Ljava/lang/Object;I)V @ 38
Event: 5.763 Thread 0x0000000002774000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000002cf4f44 method=java.lang.StringCoding$StringDecoder.decode([BII)[C @ 48
Event: 5.903 Thread 0x0000000002774000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000002de1564 method=java.util.Hashtable.addEntry(ILjava/lang/Object;Ljava/lang/Object;I)V @ 38
Internal exceptions (10 events):
Event: 6.320 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0d94238) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.322 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0e12d90) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.323 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0e25cf8) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.323 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0f49248) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.324 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0f512d0) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.324 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0f56048) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.324 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0f5bb68) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.324 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0f614f8) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.325 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0f66e08) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Event: 6.325 Thread 0x0000000002774000 Exception <a 'java/security/PrivilegedActionException'> (0x00000000c0f6c7c8) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 1312]
Events (10 events):
Event: 6.389 loading class cpw/mods/fml/common/discovery/DirectoryDiscoverer
Event: 6.389 loading class cpw/mods/fml/common/discovery/DirectoryDiscoverer done
Event: 6.407 loading class cpw/mods/fml/client/SplashProgress$SplashFontRenderer
Event: 6.407 loading class cpw/mods/fml/client/SplashProgress$SplashFontRenderer done
Event: 6.408 loading class bbu
Event: 6.408 loading class bbu done
Event: 6.408 loading class com/ibm/icu/text/ArabicShapingException
Event: 6.408 loading class com/ibm/icu/text/ArabicShapingException done
Event: 6.415 loading class cpw/mods/fml/relauncher/ModListHelper
Event: 6.415 loading class cpw/mods/fml/relauncher/ModListHelper done
Dynamic libraries:
0x00007ff68eec0000 - 0x00007ff68eef4000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\javaw.exe
0x00007ff8087f0000 - 0x00007ff8089b1000 C:\Windows\SYSTEM32\ntdll.dll
0x00007ff805bf0000 - 0x00007ff805c9d000 C:\Windows\system32\KERNEL32.DLL
0x00007ff8051a0000 - 0x00007ff805388000 C:\Windows\system32\KERNELBASE.dll
0x00007ff807a60000 - 0x00007ff807b07000 C:\Windows\system32\ADVAPI32.dll
0x00007ff8079c0000 - 0x00007ff807a5d000 C:\Windows\system32\msvcrt.dll
0x00007ff8080a0000 - 0x00007ff8080fb000 C:\Windows\system32\sechost.dll
0x00007ff807520000 - 0x00007ff80763c000 C:\Windows\system32\RPCRT4.dll
0x00007ff8076a0000 - 0x00007ff8077f6000 C:\Windows\system32\USER32.dll
0x00007ff8085f0000 - 0x00007ff808776000 C:\Windows\system32\GDI32.dll
0x00007fffff960000 - 0x00007fffffbd4000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.10586.0_none_8c15ae12515e1c22\COMCTL32.dll
0x00007ff808100000 - 0x00007ff80837d000 C:\Windows\system32\combase.dll
0x00007ff805390000 - 0x00007ff8053fa000 C:\Windows\system32\bcryptPrimitives.dll
0x00007ff808490000 - 0x00007ff8084cb000 C:\Windows\system32\IMM32.DLL
0x00000000600e0000 - 0x00000000601b2000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\msvcr100.dll
0x000000005df10000 - 0x000000005e76a000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\server\jvm.dll
0x00007ff8085e0000 - 0x00007ff8085e8000 C:\Windows\system32\PSAPI.DLL
0x00007ffff6bf0000 - 0x00007ffff6bf9000 C:\Windows\SYSTEM32\WSOCK32.dll
0x00007ff808780000 - 0x00007ff8087eb000 C:\Windows\system32\WS2_32.dll
0x00007ff803400000 - 0x00007ff803423000 C:\Windows\SYSTEM32\WINMM.dll
0x00007ff8030f0000 - 0x00007ff80311c000 C:\Windows\SYSTEM32\WINMMBASE.dll
0x00007ff805ba0000 - 0x00007ff805be3000 C:\Windows\system32\cfgmgr32.dll
0x0000000060df0000 - 0x0000000060dff000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\verify.dll
0x00000000600b0000 - 0x00000000600d8000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\java.dll
0x0000000060090000 - 0x00000000600a6000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\zip.dll
0x00007ff805ca0000 - 0x00007ff8071fc000 C:\Windows\system32\SHELL32.dll
0x00007ff805490000 - 0x00007ff805ad4000 C:\Windows\system32\windows.storage.dll
0x00007ff807310000 - 0x00007ff807362000 C:\Windows\system32\shlwapi.dll
0x00007ff804e90000 - 0x00007ff804e9f000 C:\Windows\system32\kernel.appcore.dll
0x00007ff805ae0000 - 0x00007ff805b95000 C:\Windows\system32\shcore.dll
0x00007ff804e10000 - 0x00007ff804e5b000 C:\Windows\system32\powrprof.dll
0x00007ff804e60000 - 0x00007ff804e74000 C:\Windows\system32\profapi.dll
0x0000000060080000 - 0x000000006008d000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\management.dll
0x0000000060060000 - 0x000000006007a000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\net.dll
0x00007ff804740000 - 0x00007ff80479c000 C:\Windows\system32\mswsock.dll
0x0000000060040000 - 0x0000000060051000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\nio.dll
0x00007ffff9870000 - 0x00007ffff9886000 C:\Windows\system32\napinsp.dll
0x00007ffff97a0000 - 0x00007ffff97ba000 C:\Windows\system32\pnrpnsp.dll
0x00007ff800000000 - 0x00007ff800018000 C:\Windows\system32\NLAapi.dll
0x00007ff803830000 - 0x00007ff8038da000 C:\Windows\SYSTEM32\DNSAPI.dll
0x00007ff808480000 - 0x00007ff808488000 C:\Windows\system32\NSI.dll
0x00007ff802060000 - 0x00007ff80206d000 C:\Windows\System32\winrnr.dll
0x00007ffff9780000 - 0x00007ffff9795000 C:\Windows\System32\wshbth.dll
0x00007ffff8820000 - 0x00007ffff882a000 C:\Windows\System32\rasadhlp.dll
0x00007ffffce30000 - 0x00007ffffce68000 C:\Windows\SYSTEM32\IPHLPAPI.DLL
0x00007ffffbaa0000 - 0x00007ffffbb07000 C:\Windows\System32\fwpuclnt.dll
0x00007ff804af0000 - 0x00007ff804b19000 C:\Windows\SYSTEM32\bcrypt.dll
0x000000005fe20000 - 0x000000005fe37000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\unpack.dll
0x0000000180000000 - 0x0000000180051000 C:\Users\Bruker\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-10425422450197\lwjgl64.dll
0x00007ff801280000 - 0x00007ff80128a000 C:\Windows\SYSTEM32\VERSION.dll
0x00007fffe8140000 - 0x00007fffe8269000 C:\Windows\SYSTEM32\OPENGL32.dll
0x00007ff8013d0000 - 0x00007ff8013fe000 C:\Windows\SYSTEM32\GLU32.dll
0x00007fffe7f30000 - 0x00007fffe802a000 C:\Windows\SYSTEM32\DDRAW.dll
0x00007ff802140000 - 0x00007ff802148000 C:\Windows\SYSTEM32\DCIMAN32.dll
0x00007ff8047f0000 - 0x00007ff804807000 C:\Windows\SYSTEM32\CRYPTSP.dll
0x00007ff804420000 - 0x00007ff804454000 C:\Windows\system32\rsaenh.dll
0x00007ff8045d0000 - 0x00007ff8045ef000 C:\Windows\SYSTEM32\USERENV.dll
0x00007ff804910000 - 0x00007ff80491b000 C:\Windows\SYSTEM32\CRYPTBASE.dll
0x00007ffffb8e0000 - 0x00007ffffb8f6000 C:\Windows\SYSTEM32\dhcpcsvc6.DLL
0x00007ffffba80000 - 0x00007ffffba9a000 C:\Windows\SYSTEM32\dhcpcsvc.DLL
0x000000005dd70000 - 0x000000005df08000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\awt.dll
0x00007ff8083b0000 - 0x00007ff808471000 C:\Windows\system32\OLEAUT32.dll
0x00007ff803600000 - 0x00007ff803679000 C:\Windows\system32\apphelp.dll
0x00007ff803790000 - 0x00007ff803826000 C:\Windows\system32\uxtheme.dll
0x00007ff807b10000 - 0x00007ff807c6a000 C:\Windows\system32\MSCTF.dll
0x00007ff802c40000 - 0x00007ff802c62000 C:\Windows\system32\dwmapi.dll
0x0000000059c20000 - 0x000000005ba82000 C:\Windows\SYSTEM32\nvoglv64.DLL
0x00007ff807c70000 - 0x00007ff808099000 C:\Windows\system32\SETUPAPI.dll
0x00007ff802f70000 - 0x00007ff802f83000 C:\Windows\SYSTEM32\WTSAPI32.dll
0x00007fffe64d0000 - 0x00007fffe665c000 C:\Windows\SYSTEM32\dbghelp.dll
0x00007ff8038e0000 - 0x00007ff803907000 C:\Windows\SYSTEM32\DEVOBJ.dll
0x00007ff804ea0000 - 0x00007ff804ef5000 C:\Windows\system32\WINTRUST.dll
0x00007ff804e80000 - 0x00007ff804e90000 C:\Windows\system32\MSASN1.dll
0x00007ff804fd0000 - 0x00007ff805198000 C:\Windows\system32\CRYPT32.dll
0x00007ff804300000 - 0x00007ff804331000 C:\Windows\SYSTEM32\ntmarta.dll
0x00007ff8011e0000 - 0x00007ff801271000 C:\Windows\SYSTEM32\mscms.dll
0x00007fffebfa0000 - 0x00007fffebfe2000 C:\Windows\SYSTEM32\icm32.dll
0x00007ff804570000 - 0x00007ff8045c6000 C:\Windows\SYSTEM32\WINSTA.dll
0x0000000070a40000 - 0x0000000070adc000 C:\Users\Bruker\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-10425422450197\avutil-ttv-51.dll
0x0000000065980000 - 0x00000000659d6000 C:\Users\Bruker\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-10425422450197\swresample-ttv-0.dll
0x000000006eb80000 - 0x000000006ec50000 C:\Users\Bruker\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-10425422450197\libmp3lame-ttv.dll
0x00007fffd2550000 - 0x00007fffd38f4000 C:\Users\Bruker\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-10425422450197\libmfxsw64.dll
0x00007fffe8290000 - 0x00007fffe83f3000 C:\Program Files (x86)\Mirillis\Action!\action_x64.dll
0x000000005c8e0000 - 0x000000005c983000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCR90.dll
0x00007ffffcd90000 - 0x00007ffffcd9b000 C:\Windows\SYSTEM32\AVRT.dll
0x00007ffffd020000 - 0x00007ffffd0e8000 C:\Windows\SYSTEM32\WINHTTP.dll
0x000000005c800000 - 0x000000005c8d3000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCP90.dll
0x00007fffe7e00000 - 0x00007fffe7f2b000 C:\Users\Bruker\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-10425422450197\twitchsdk.dll
0x00007ff807870000 - 0x00007ff8079b3000 C:\Windows\system32\ole32.dll
0x00007ffff84e0000 - 0x00007ffff8789000 C:\Windows\SYSTEM32\WININET.dll
0x00007fffff350000 - 0x00007fffff3c0000 C:\Windows\SYSTEM32\mmdevapi.dll
0x00007ff802dc0000 - 0x00007ff802f46000 C:\Windows\SYSTEM32\PROPSYS.dll
0x000000005fa60000 - 0x000000005fa91000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\jpeg.dll
0x000000005c7c0000 - 0x000000005c7fc000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\lcms.dll
VM Arguments:
jvm_args: -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M -Dos.name=Windows 10 -Dos.version=10.0 -Djava.library.path=C:\Users\Bruker\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-10425422450197
java_command: net.minecraft.launchwrapper.Launch --username ImHulks --version 1.7.10-Forge10.13.4.1558-1.7.10 --gameDir C:\Users\Bruker\AppData\Roaming\.minecraft --assetsDir C:\Users\Bruker\AppData\Roaming\.minecraft\assets --assetIndex 1.7.10 --uuid 8c040c0ea9b34fb2ba18d6807adff2a8 --accessToken 3f6e3f542fd4430b83a71c9ab71b0f39 --userProperties {} --userType legacy --tweakClass cpw.mods.fml.common.launcher.FMLTweaker --nativeLauncherVersion 307
java_class_path (initial): C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\net\minecraftforge\forge\1.7.10-10.13.4.1558-1.7.10\forge-1.7.10-10.13.4.1558-1.7.10.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\net\minecraft\launchwrapper\1.12\launchwrapper-1.12.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\ow2\asm\asm-all\5.0.3\asm-all-5.0.3.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\com\typesafe\akka\akka-actor_2.11\2.3.3\akka-actor_2.11-2.3.3.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\com\typesafe\config\1.2.1\config-1.2.1.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-actors-migration_2.11\1.1.0\scala-actors-migration_2.11-1.1.0.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-compiler\2.11.1\scala-compiler-2.11.1.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\plugins\scala-continuations-library_2.11\1.0.2\scala-continuations-library_2.11-1.0.2.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\plugins\scala-continuations-plugin_2.11.1\1.0.2\scala-continuations-plugin_2.11.1-1.0.2.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-library\2.11.1\scala-library-2.11.1.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-parser-combinators_2.11\1.0.1\scala-parser-combinators_2.11-1.0.1.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-reflect\2.11.1\scala-reflect-2.11.1.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-swing_2.11\1.0.1\scala-swing_2.11-1.0.1.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-xml_2.11\1.0.2\scala-xml_2.11-1.0.2.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\lzma\lzma\0.0.1\lzma-0.0.1.jar;C:\Users\Bruker\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\Bruker\AppData\Roaming\.minec
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Razer Chroma SDK\bin;C:\Program Files\Razer Chroma SDK\bin;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Skype\Phone\;
USERNAME=Bruker
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 8.1 , 64 bit Build 9600
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 94 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, lzcnt, tsc, tscinvbit, bmi1, bmi2
Memory: 4k page, physical 8341560k(5359648k free), swap 10569784k(6828340k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.25-b02) for windows-amd64 JRE (1.8.0_25-b18), built on Oct 7 2014 14:25:37 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed Jun 29 15:59:20 2016
elapsed time: 6 seconds (0d 0h 0m 6s)
