For some reason there is only audio when I try to play x265 files. Yes, I know that I can't decode it with my cpu and I have to use hardware accelaration. I am using core i5 4670k with geforce gtx 780 so everything should work just fine. I have the Nvidia pure video box checked in my video options and I don't know that to do to fix the problem. Obviously I am using the newest stable whql nvidia drivers and all that good stuff. I should also mention that everything works just fine on VLC. Thanks in advance for all the help you can give me
