Rasmus
PC Specification: i7 6700k | geforce gtx 1080 | windows 10
Which is best to use?
Tue Sep 27, 2016 7:40 pm
Hey!
So I'm using Action! and I was wondering. Which "File Format" is the best one to use for recording gaming videos?
I have theese to pick between:
AVI
MP4
MP4 (Intel Quick Sync)
MP4 (NVIDIA NVENC)
MP4 (NVIDIA NVENC HEVC)
Which one would be the best if I want the BEST quality possible. I do not care of file size or anything. Just want the best quality possible.
My hardware spec:
Code: Select all
Operating System: Windows 10 Pro 64-bit
CPU: Intel Core i7 6700K @ 4.00GHz Skylake
RAM: 16GB
Graphic Card: NVIDIA Gainward GeForce GTX 1080 Phoenix GLH
Would love if someone could share which one is best for the HIGHEST quality =)
Thanks.
Re: Which is best to use?
Fri Sep 30, 2016 3:05 pm
Everyone has it perks. If you want to go for the best quality but don't care for disk space select AVI. If you would like to get a good quality and low file size select MP4 HEVC.
amyarendt
PC Specification: win8
Mon Apr 03, 2017 10:18 am
AVI
MP4 Both are good to use.
Return to “General Topics”
