pme
PC Specification: Intell i7 x980, GTX780Ti, W7 Ult x64
Frame rate problems after update to 1.31.5
Thu Sep 29, 2016 2:31 pm
I have always had good results with Action, but after the last update (v1.31.5) I have several problems.
I use Action to record Flightsimulator Prepar3D v3.3 in an active desktop region. My desktop has a 1920 x 1200 resolution, and I record in 1920 x 1080, because that is the normal full HD. This has never been a problem, and I was satisfied with the results. The films were published on You Tube.
After the update the frame rate in the HUD dropped to 1 - 4 frames, and in the game from around 30 to 5 - 15. It recorded in mp4 format only, even if I changed the format to AVI. Suddenly I couldn't make fluent films anymore.
I decided to remove the new version, and installed an earlier version of the program (1.29.0.0), and all the problems were over. With this earlier version there are no stutters, and frame rate is up to about 30 fps in both the game as well as in the HUD. And the program records in AVI format again.
Incidentally; when removing Action from the computer, not all software was removed. After a restart, and a reinstall (as administrator), it came up with the same settings as before. There still remained some data in the Program Data map.
For the time being I will keep using the older version. The question of course is; what is changed in the new version that causes those low frame rates, and it not being able to record in AVI format? Will there be an update, or should I keep using the earlier version?
Specifications:
• OS: Windows 7 64bit
• Video card: NVIDIA GTX780Ti (MSI)
• Memory: Computer12Gb, video card 3gb
• Monitor Resolution: 1900 x 1200 (x2)
• Game Problem: Prepar3D v3.3, recorded in desktop region 1920 x 1080.
• Video Type: Not recording in AVI. MP4 no problem.
King regards.
Peter
Re: Frame rate problems after update to 1.31.5
Fri Sep 30, 2016 3:05 pm
Have you cleared your Action registry during re-installation?
pme
Fri Sep 30, 2016 7:53 pm
I don't know exactly what you mean by "cleaning the action registry". I did clean the Windows registry before installing action.
Kind regards,
Peter
snack95
PC Specification: windows 10
Wed Jan 11, 2017 11:02 am
How to switch to the old version?
Atticus X
PC Specification: GTX 470m Sager
Tue Jan 01, 2019 9:29 pm
How do you switch to an older version of Action!?
Wed Jan 02, 2019 7:39 am
MgSolidus
PC Specification: win7/gtx1060/i5-3570/Z77SL-50K/16gbram
Thu Aug 15, 2019 7:47 am
Is there solution for "error 104"? I use 1.31.5 and stop update after visual design change i didn't like.
Return to “General Topics”
