user82
PC Specification: Q6600,Ati HD-4850
Time-Search Pictures with VC1 - SOLVED
Sun Jul 11, 2010 6:52 pm
Hi!
i have some trouble with those:
on one m2ts h264 and all m2ts VC1 streams
this is a good feature, perhaps you can fix it?
Greetings
user
Helios
Re: Time-Search Pictures with VC1
Mon Jul 12, 2010 7:36 am
Hi user82,
please provide some more details, I'm not sure what's the problem. SmartSeek does not show?
regards,
user82
Mon Jul 12, 2010 8:12 am
Helios wrote:Hi user82,
regards,
yes if you call it smartseek it is exactly the problem. It does not show the small preview when seeking(after leavign the cursor ~20sec at the position no picture, normally after ~1sec a preview is shown)
perhaps you can spot the Problem with some Mediainfos:
Does work:
Does not work:
So on VC1 it never worked, in H264 most of the time
Helios
Mon Jul 12, 2010 4:03 pm
Do you open those files directly from optical drive?
SmartSeek is automaticly disabled when playing from optical discs. You can try to copy the file to HDD.
regards,
user82
Mon Jul 12, 2010 6:58 pm
Helios wrote:Hi,
regards,
yeah i did.
Can I enable it for discs?
it does make sense for optical drives but not for mounted isos ;)
greetings
user
Helios
Tue Jul 13, 2010 7:17 am
user82 wrote: Can I enable it for discs?
Unfortunately you can't, but I see the issue now. We will consider this option, but generally we are trying to avoid too much options in settings.
user82
Tue Jul 13, 2010 1:28 pm
mounting the disc in a ntfs folder solves the problem :P
so if i am the only one interested in this feature it might be useless to think about the option
