Francesco
PC Specification: E3300, Ati4650, ESP-1010e, 4gb, W7x64
"real" room correction with Convolver, is it possible?
Thu Dec 15, 2011 9:24 am
Hi all, I'm considering SplashPro for my HTPC, I've downloaded the demo and I like it by now.
My idea is to use an external soundcard with 8 analog outputs (esi esp-1010e, which I already have) plus this software configuration for audio processing (drc, bass management, delay management etc etc).
Do you think it's possible? Can I route SplashPro audio output to ASIO and then to Convolver (or some other convolution engine)?
Thank you, bye! :)
Francesco
P.J
Re: "real" room correction with Convolver, is it possible?
Fri Dec 16, 2011 6:51 pm
I had a similar idea like you: http://www.mirillis.com/forum/viewtopic.php?f=18&t=2705
Supporting VST would be great too.
Thu Mar 22, 2012 12:25 am
Thanks for your suggestion.
We will add this to out list to check but we do not expect to work on it in the near future.
