launellp
PC Specification: AMD FX6300,MSI GTX750TI,8GB RAM,Windows7
I can´t open my Mirillis Action... + video
Sat Oct 15, 2016 3:25 pm
Hey,
I have a problem!
I can´t use my Mirillis Action it´s start but than it´s close!I can´t see a window nothing!
Here a video from the problem.
https://www.youtube.com/watch?v=sJZtxj0lQLI
My pc:
Windows 7
AMD FX 6300
MSI GTX 750Ti 2GB
8GB RAM
wasaicornel
PC Specification: windows 10 64bit
Re: I can´t open my Mirillis Action... + video
Fri Oct 28, 2016 4:26 pm
I have same problem.
Reinstalled windows and nothing changed.
launellp wrote:Hey,
I have a problem!
My pc:
Windows 7
AMD FX 6300
MSI GTX 750Ti 2GB
8GB RAM
wasaicornel
Sat Nov 05, 2016 9:39 pm
I got an answer from Mirillis support.
My problem was "Thank you for your diagnostic report. This issue is related to your AverMedia hardware and streaming engine that is used in Rec Central. Uninstalling this application should fix your launch issue."
I unninstalled avermedia and after it worked. :D
Mon Nov 07, 2016 4:50 pm
As a temporary fix you could also open your Stream Engine (if you are not currently using it) and uncheck "Enable Streaming Engine". Action should start with this option disabled.
Hioctane321
PC Specification: AMD FX(tm)-6100, R9 270x 2GB, 8GB Ram
Tue Nov 08, 2016 12:32 am
What if you don't have Avermedia and your getting the same issue? As in my case.
Hioctane321
Thu Nov 10, 2016 4:04 am
Hioctane321 wrote:What if you don't have Avermedia and your getting the same issue? As in my case.
I updated my windows 10 to the aniversary edition 1607 and action now loads.
Users browsing this forum: No registered users and 48 guests
