detroit1
PC Specification: windows 7 ultimate
Mirillis is crashing after opening
Mon Oct 17, 2016 2:47 pm
Just started this morning. I was using it to record video, then I stopped the recording
software was open; then it crashes and I get the windows is searching for solution
I restarted the computer; same thing. I re installed 1.31.5; same result
I can't find older versions on the web site
I have Windows 10 Enterprise, Nvidia 980Ti
each time I open Action; within 10 seconds, it will crash
Does anyone know how to correct this ? I need to use this software asap
RogueDK
PC Specification: i7, 980ti, Win7ul
Re: Mirillis is crashing after opening
Tue Mar 07, 2017 3:08 pm
I get sort of the same issue: On my system it fails to start and I get a "Action has stopped working" - error. Every single time.
Wed Mar 08, 2017 6:43 am
Please try removing or moving to another location all your video files from your video output folder. Once your video folder is empty please run Action! and see if it's still crashing.
Rene78
PC Specification: Windows 7 (64)
Fri Mar 10, 2017 6:11 pm
Piotr wrote:Please try removing or moving to another location all your video files from your video output folder. Once your video folder is empty please run Action! and see if it's still crashing.
Same issue here.
I tried the above approach and a few other things I could think of such as updating graphics card drivers.
No effect.
Please keep the advice coming.
Thank you.
