sweduck75
Action running but no window
Sat Nov 05, 2016 12:35 pm
Hi!
Was really excited to try out Action v2 and installed but upon opening the program it can't be seen. The process is running but there is no way to access the program.
I've tried uninstalling and deleting all info in the Registry, restarting computer and install again but same thing.
(Click the image if you only se half)
Any ideas?
sweduck75
Re: Action running but no window
Sat Nov 05, 2016 4:00 pm
I got a speedy reply from the Support. It seems that Action won't work if you have Avermedia hardware and AverMedia Rec Central and Stream Engine. Uninstalling those two makes Action work again.
They are working on a fix. :)
Mon Nov 07, 2016 4:51 pm
As a temporary fix you could also open your Stream Engine (if you are not currently using it) and uncheck "Enable Streaming Engine". Action should start with this option disabled.
