Jericho
PC Specification: i7 950, gtx 970, 12g.
Action! Color Problems
Tue Nov 08, 2016 4:45 pm
English:
When I capture with Action! I have a problem with all formats. Frames are fine, video and sound in themselves too. But the other day I realized that after an update the program captured me with another range of color.
I have taken a JPEG image capture with the same program in a RED title and I have captured it in Avi, and in other formats and I encounter the color error in the capture. It is as if the color palette changes, and instead of red it captures an orange.
I have the system from Nvidia with the monitor in full range 0-255, so that's not it.
I have captured with another program and I do not have this color error, but as I bought the Action! In its complete and commercial version, I would like a solution.
I leave a comparison, to the left is the JPEG (Captured with action!) And to the right is the result AVI (A FullHD and high capture settings and 0-255 range). I repeat that this happens with all formats. And I have discarded many things and tried other capture programs. Yes or if it is the Action! Or something related to its operation.
I would like help to continue working in the normal way, and to capture the videos in the right color.
Thank you very much and greetings. :roll:
Image:
Left JPEG (Action! Correct Color) Right Bad color Video Capture
Color problem.jpg (244.89 KiB) Viewed 12708 times
Español:
Hola,
Cuando capturo con el Action! tengo un problema con todos los formatos. Los Frames están bien, el video y el sonido en si mismos también. Pero el otro día me percate que después de una actualización el programa me capturaba con otra gama de color.
He sacado una captura de imagen JPEG con el mismo programa en un titulo ROJO y he capturado en Avi, y en otros formatos y me encuentro con el error de color en la captura. Es como si cambiara la paleta de colores, y en vez de rojo captura un naranja.
Tengo el sistema desde Nvidia con el monitor en rango completo 0-255, así que eso no es.
He capturado con otro programa y no tengo este error de colores, pero como compre el Action! en su version completa y comercial, quisiera una solución.
Dejo una comparativa, a la izquierda esta el JPEG (Capturado con action!) y a la derecha esta el resultado AVI (A FullHD y configuraciones altas de captura y 0-255 de rango). Repito que esto pasa con todos los formatos. Y he descartado muchas cosas y probado otros programas de captura. Si o si es el Action! o algo relacionado con su funcionamiento.
Quisiera ayuda para poder seguir trabajando de manera normal, y poder capturar los videos en color adecuado.
Desde ya muchas gracias y un saludo.
Re: Action! Color Problems
Thu Dec 01, 2016 2:01 pm
AVI or MP4 format?
hnagai
PC Specification: nvidia gtx950, win 10
Sat Jan 13, 2018 9:17 am
I have a similar problem. The red color is not displayed correctly in avi and mp4. Changing the settings did not help. This has been going on for a very long time (updating to the new version does not help). And even the version of Windows, the video card does not affect this (I tried on Windows 7, 8.1, 10 and maps Gtx650 and Gtx 950).
