Keith
PC Specification: Windows XP
calling from another program
Fri Dec 16, 2011 4:40 am
I want to call Splash Pro from another prog, have it run through all the video clips in a particular directory and then exit so that I can then run another prog to show the photos. However, although I can run Splash Pro and get it to do this, it will continue to run through all the video clips ad infinitum and I can't get it to stop without manual intervention. Can anyone tell me how to get it to just play all the clips in a directory once and then exit?
Re: calling from another program
Thu Mar 22, 2012 12:25 am
We plan to add an option to close Splash on stop to make it easy to use with 3rd party software.
Please check loop option on the bottom control pannel as you probably have this enabled and thats why it plays the file all the time.
