mahiney
PC Specification: Windows 7, GTX 260, i7 core
Capture frame, no scrub, file associations
Mon Jul 19, 2010 5:37 pm
Hello. The images created with Capture Frame are vertically squeezed - can't use these! It's like everything is way narrow.
Also, is there a way to change file associations? I didn't want Splash to control ALL my files, & if I had selected 'no' at install would it not recognize them?
Lastly, it's just not right that you can't scrub the time-line, absolutely need this.
It's a great program otherwise, saved the day for me on one level, but if the issues above can't be resolved then I would request a refund because I need that in a video program. Thanks for all your work, I'm sure people will love it.
Re: Capture frame, no scrub, file associations
Mon Sep 20, 2010 4:03 pm
Hi, capture frame option captures the original video frame ignoring aspect ratio. We are going to improve this soon.
We also plan to add your other suggestions in future verssion.
At the moment file assiocciations may be managed through Windows system only.
