ExpertPL
PC Specification: i7 4790K, GeForce GTX 970, Windows 10
mirillis.com ERR_CONNECTION_REFUSED
Thu Nov 24, 2016 9:14 am
Hi there!
I've been using trial version of Action! but it expired, so I thought I'd check how much costs full version and consider buying it, but when I'm trying to open mirillis.com I'm getting ERR_CONNECTION_REFUSED error everytime. It doesn't matter which browser I'm using, it's still the same. Do you know how to fix it?
Re: mirillis.com ERR_CONNECTION_REFUSED
Mon Nov 28, 2016 6:56 pm
Try restoring your hosts file back to default.
Joeswinn12
PC Specification: windows7
Sat Jan 07, 2017 6:36 am
Thank you
Maurice Erdmann
PC Specification: AMD 3500X, GTX 1650 Super, Windows 10
Thu Apr 08, 2021 10:18 am
Hi!
I think the ERR_CONNECTION_REFUSED error message appears almost always due to a client-side misconfiguration or a technical problem on the user’s side means that you have the chance to fix the problem on your own.
Return to “General Topics”
