ProJH
PC Specification: GTX 1080TI
Action! Doesn't Work On The Division
Sun Nov 27, 2016 8:35 pm
Game capture and select application options doesn't work for The Division. Active screen acts also weird. It records slow motion and another issues. In every other game I play, there is no issue.
The hud is not visible on The Division. If you try to capture a video even hud is invisible, the video has lots of issues.
Examples : FPS problems, sound keeps cutting of.
I tried every display settings ( borderless[windowed] fullscreen, fullscreen, windowed ) but the result is same.
Re: Action! Doesn't Work On The Division
Mon Nov 28, 2016 6:57 pm
Does this game runs in DX12 or 11?
