Fexo
PC Specification: i5-4460, R9 270X 4GB, Windows 8.1
Random Lag *Fix*
Tue Nov 29, 2016 4:29 am
So recently I was having an issue were Action! was for some reason lagging my game, and it usually doesn't.
I have since found a solution to this, which is to turn the priority of Action! to normal in task manager.
If anyone else was having this issue I hope it helps!
Re: Random Lag *Fix*
Thu Dec 01, 2016 1:41 pm
Could you please check if the same issue occurs if your HUD is not visible?
Fexo
Wed Dec 07, 2016 11:39 pm
radi wrote:Could you please check if the same issue occurs if your HUD is not visible?
Still happens when not visible
Thu Dec 08, 2016 12:20 pm
So at this moment the only working solution to your problem is to lower Action.exe priority to Normal?
Fexo
Fri Dec 23, 2016 12:34 am
yes
zhker
PC Specification: Win 10, i7 3770, GTX 1080, 16gb DDR3
Tue Dec 27, 2016 3:26 am
Oh. My. Universe... thank you for the tip about process priority... It works now! No audio lag or audio-stuttering... Action is good, but these issues.... with audio, or webcam shutting off when taking screenshots... not fixed since june... not nice, simply put.
