CruxXial
PC Specification: I7 6950x gtx 1080 win 10 pro x64
Any fix for MP4 in 2.0.5
Thu Dec 01, 2016 8:49 am
Is there any fix coming soon to fix mp4 recording in 2.0.5
If i try to record in mp4 with ultra settings and voice and systemsound in seperate files i can`t edit the video in vegas pro 14
because the video file is missing and when i do allow to combine the sounds all of a sudden the sound totally disappears in the recorded file. as if everything was muted. please release a fix for this problem as i need to have those two seperated as do others too i guess.
i7 6950x
gtx 1080
win10 pro x64
rode nt-usb
soundblaster x7
Re: Any fix for MP4 in 2.0.5
Thu Dec 01, 2016 1:37 pm
This issue is not related to Ultra settings but multiple audio/video sources. This issue has been reported to Sony Vegas technical staff as they do not properly recognize files with multiple media tracks.
CruxXial
Tue Dec 06, 2016 11:11 am
Ok thanks but that doesn't solve the problem that the sound is completely mutet after about 2 1/2minutes of recording. There is absolutely nothing. No ingame sound no mic sound either. Maybe you should add the option to record sound as raw pcm to avoid that problem?
