Gokushivum
PC Specification: CPU:Amd FX:8350 GPU:Nvidia GTX1060 Win10
When launching Action only HUD opens
Sat Dec 03, 2016 2:31 am
OS: Windows 10
Video Card: NVIDIA GTX 1060
Memory: 16 GB
Monitor Resolution: 1920x1080
It will show it is open in the task manager, but it isnt open in the quick menu, task bar or anywhere else. Only the HUD is open
Re: When launching Action only HUD opens
Mon Dec 05, 2016 1:06 pm
Please try pressing "0" (zero) to reset window position and see if Action will appear.
