keraviln
PC Specification: Windows 10 64-bit, AMD Radeon M260
Action Mirillis not using Discrete GPU
Tue Dec 06, 2016 12:39 pm
After upgrading to Windows 10 and using the new Action Mirillis 2.0.7.0 (as well as fully updated AMD & Intel Graphics Drivers) I realised that Action Mirillis was not using the Discrete GPU.
I checked the settings in the AMD Radeon Additional Settings window and Action.exe, action_x64.bin & action_x86.bin were all set to 'High Performance' (aka. AMD's discrete GPU). However, when using Action Mirillis (and upon checking it with the Switchable Graphics Monitor), I found that Action Mirillis was ignoring this setting and using the Intel Integrated Graphics instead.
Any other application that I have set to 'High Performance' uses the AMD Radeon GPU instead of the Intel Integrated Graphics.
Any solutions or ideas? Is this a bug with Mirillis, Windows 10 and AMD's software?
Thanks!
Re: Action Mirillis not using Discrete GPU
Tue Dec 06, 2016 4:32 pm
Could you please upload your dxdiag report to pastebin?
keraviln
Thu Dec 08, 2016 7:14 am
DxDiag Report:
http://pastebin.com/j1VzUR41
Hope this helps, and thanks for looking into it!
Thu Dec 08, 2016 12:19 pm
Check if there are newer video drivers for your Intel iGPU.
keraviln
Thu Dec 08, 2016 2:26 pm
I checked, the Intel Graphics Drivers are the newest version available.
