coyd
PC Specification: Window 8.1 A10 5750m Radeon HD 8970m
0xc0000409 What happen ? and how to fix ?
Tue Dec 20, 2016 2:50 pm
It appear
Action.exe - Application Error
The exception unknown software exception (0xc0000409) occured in the application at location 0x00470464
Click on OK to terminate the program
and then i can't open it again
Re: 0xc0000409 What happen ? and how to fix ?
Tue Dec 20, 2016 3:15 pm
Did you experienced any issues during installation or update?
coyd
Tue Dec 20, 2016 5:34 pm
No, this is my first issue
Wed Dec 21, 2016 8:56 am
Could you please upload your DxDiag report to pastebin and post the link here?
coyd
Wed Dec 21, 2016 9:27 am
Wed Dec 21, 2016 5:03 pm
Thanks. It seems that your video drivers are from March this year. Could you please check if updating your drivers makes any difference?
coyd
Wed Dec 21, 2016 9:10 pm
when I open it . It will only appear in background processes in task manager
Thu Dec 22, 2016 10:05 am
Do you use any anti-virus? Does Action run properly in Safe Mode?
coyd
Thu Dec 22, 2016 10:23 am
I use Avast and It doesn't work even in safe mode
Thu Dec 22, 2016 1:28 pm
Have you tried the clean re-installation? Here is short guide:
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
