couchpotato23
PC Specification: i7-6700, 16GB RAM, GT740, 10-64build1607
QuickSync alongside discrete GPU in Windows 10
Wed Dec 21, 2016 5:58 pm
Hello all,
A quick search of this forum didn't reveal any answer to my question. I apologize in advance if the answer's already out there and I missed it.
The following guide works perfectly for Windows 7: https://mirillis.com/en/products/tutori ... ktops.html
Has anyone had success performing the same sort of trick with Windows 10 build 1607?
Clicking "Detect" in Windows 10 simply shows red text saying "Didn't detect another display.", and I can't go any further.
I'd like to be able to use Quick Sync encode options whisle reserving GPU power for other uses.
Thanks in advance for any responses.
Re: QuickSync alongside discrete GPU in Windows 10
Thu Dec 22, 2016 2:00 pm
As far as I know there is no need to detect additional desktop to make it work with IQS on Windows 10. Make sure that you use latest version and iGPU is enabled in your BIOS settings.
jax<>
PC Specification: Intel 3770K, Gigabyte 660GTX, Windows 7
Sun Jan 08, 2017 8:43 pm
Yes as long as igpu is enabled in bios, and quicksync is selected in Action is should work, I have 4790k and Discrete card 980ti as primary graphics, if you open GPUZ and select HD4600 from drop down box if you stasrt a recording of say your desktop, with the sensors tab selected your see the GPU core boost to 1300MHz, or what ever your igpu boost clock is...
so no need for dummy monitor
