KingClaw
PC Specification: i5 6600K MSI RX 480 GAMING X 8GB W7 64X
Action! crashing on startup. Windows 7 64-bit.
Sat Dec 24, 2016 12:32 am
Hello, I am having issues with my Mirillis Action! when I launch the program. When I open Action it just instantly crashes.
What I have done to attempt to solve my issue.
1. Uninstall Action and Install again.
2. Opened it with Compatibility options set to Windows 7 and given it Administrative access.
3. Made sure the Action! service is up and running.
4. Tried an older version of Action!.
5. Restarted my PC many times.
6. Tried to install and open while internet disabled.
I have no clue what else to do!
My PC hardware is not the issue if that was in mind.
Please help me anyone! Thank you!! :D :( :D :cry: :!:
Screenshot of what I get when launching Action!
Re: Action! crashing on startup. Windows 7 64-bit.
Wed Dec 28, 2016 4:21 pm
Did you recorded any videos before this started to happen?
oberst78
PC Specification: i7 7700K, GTX 980 TI, Windows 10 Home
Wed Feb 15, 2017 5:23 pm
Same problem, but I get no error. Immediately close the application. I have windows 10 Home directx12.
link of the video where you see the problem
https://www.youtube.com/watch?v=gq8TuUIOQOk
Thu Feb 16, 2017 7:16 am
Please try removing or moving to another location all your video files from your video output folder. Once your video folder is empty please run Action! and see if it's still crashing.
oberst78
Thu Feb 16, 2017 10:14 am
Piotr wrote:Please try removing or moving to another location all your video files from your video output folder. Once your video folder is empty please run Action! and see if it's still crashing.
I formatted the PC after changing the motherboard, so it is a fresh installation, in this case, should take the default folder
Reddyt
PC Specification: Windows 10,Intel corei7 7500U Nivi 940MX
Mon Jun 12, 2017 4:34 pm
I dont have any recording!
Im running action first time on my computer...
Just crash,procces is in task manager but Action isnt running!!What to do!?
Tue Jun 13, 2017 6:16 am
Please contact our technical support via support@mirillis.com
waterboy
PC Specification: GTX970 SLI i7-4790 Win10Home ram16GB
Mon Jun 26, 2017 7:28 pm
oberst78 wrote:Same problem, but I get no error. Immediately close the application. I have windows 10 Home directx12.
I see your desktop has MSI Afterburner, it always running with Rivatuner.
Rivatuner has issue with Action! on Windows10 64bit
go exclude Action_x64.bin image
FYI, http://forum.mirillis.com/viewtopic.php?f=17&t=38983
but on Windows7 64bit I have not tested. go try it, if success please tell others.
goldemomma010
PC Specification: Intel core i3, Radeon, Windows 7.
Sat Sep 14, 2019 3:57 pm
Maybe the Mirilis Action! is not compatible with your PC because some application are not compatible in the PC.
