Bernd F.
PC Specification: CPU-6700K, Geforce 1070 GTX , WIN10 ;SSD
Software font size changed
Sun Jan 08, 2017 10:55 am
Hallo Team
ask for help
With a 4K display the operating menu is too small, and almost unreadable.
How can I change it?
Are there possibilities here?
Thanks
Re: Software font size changed
Fri Jan 20, 2017 7:11 am
Unfortunately you cannot change its size.
Dobs
Fri Feb 03, 2017 8:26 pm
Requires software development to make scaleable font...I mean who would 4k resolution, its not like most cards can push 4k now or something.
I'd be happy with a product that worked when you clicked on it. SPLASH worked in the past....no issues....now I "downgraded to 2.0.4" and it starts and shuts down..... let me guess...I need to re-enable the nag account control to make it work?
Return to “Splash 2.0”
