Dinadan
PC Specification: FX 4300 3.8 quad, geforce 750TI FTW, W10
Can't acess the website
Mon Jan 09, 2017 9:28 pm
My trial time has ended and I would like to buy it. But since yesterday I can't acess the website. How can I buy?
Thanks in advance.
Re: Can't acess the website
Tue Jan 17, 2017 6:50 am
It seems that you have blocked our website. It's usually caused by third party 'activators' for Action. To remove this kind of activity please follow these steps:
1. For firewall blocking rules:
Go to your Windows Firewall with Advanced Security. Then from the left menu select Outbound Rules.
Find following IP address: 176.31.241.10 right click on it and select Delete.
Find following IP address: 91.121.143.139 right click on it and select Delete.
2. For hosts file
Localize your hosts file (%WINDIR%\system32\drivers\etc\hosts).
Open it as administrator using notepad.
Find following lines:
127.0.0.1 mirillis.com
127.0.0.1 http://www.mirillis.com
127.0.0.1 serwer2.paka-service.com
127.0.0.1 ns386119.ovh.ne
127.0.0.1 mirillis.pl
Delete all those lines above and then save your hosts file.
After all these steps were taken please reboot your PC. If you have followed steps above properly you should be able to use our software properly.
Return to “General Topics”
