maquinabo
PC Specification: Windows 10
Animated subtitles
Thu Jan 12, 2017 5:12 am
Hi, I've been watching anime and movies in the Splash Pro video player for a while, and sometimes the subtitles appear with some kind of coding that should be hidden, and until the respective anime or movie is finished.
Usually only happens with animes, because of this, totally disrupts the reading, and I do not know how to arrange it, would anyone know?
Re: Animated subtitles
Mon Jan 23, 2017 8:47 am
Hello, thank you for contacting us. Please report this issue to our technical support via support@mirillis.com They will investigate this issue.
pikachu68
PC Specification: paint
vex
Mon Jul 09, 2018 7:34 am
thnak you for sharing useful information
Sttot
PC Specification: windows 7
Thu Mar 04, 2021 9:30 am
I guess the format of subtitles is not supported yet.
Splash does not support all subtitles formats yet, and Splash Lite has some feature limitations including no support for PGS subtitles. Do you know what subtitles format is it in your video file?
Thely1946
PC Specification: Intel Core i7-10700K, NVIDIA GeForce RTX
Tue Jun 24, 2025 8:52 am
You could try checking the subtitle encoding settings in Splash Pro—sometimes switching to UTF-8 can fix weird character issues, especially with anime subs.
