GoodGodd
PC Specification: i7 6700k, GTX 1080, Windows 10 64bit
After new update, action crashing my game.
Fri Jan 20, 2017 4:30 pm
Hi there,
After new update I can't run MU online game client. Action switching it off, when is running or crashing game client after I start the software. Any help please?
All software's and drivers are updated.
Everything was fine before update.
GoodGodd
Re: After new update, action crashing my game.
Mon Jan 30, 2017 2:58 pm
johnniewalk wrote:I think the reason for this error may be still your game is not updated or while updating may be something has happened. Better again try to install it..
Thanks for answer.
Mu online game client is up to date. It's working on C++ and .NET, they both are up to date. Everythink was fine before update. After update Action! just switching off game.
I also can't recording mic voice when recoding game or live streaming with cam or whitout. Mic is working just check it in windows and its working fine in skype and discord etc.
Will contact with technical support and let you guys know what they will say.
my spec
OS: windows 10
CPU i7600k
RAM: 3600 MHZ
GPU: GTX 1080
AprilRussell
PC Specification: CPU model
Thu Oct 26, 2017 1:59 am
Thanks for the useful post, for the solution.
