Geowil
PC Specification: Intel I7-5960X, 2x290X, Win 8.1 Pro
Action! 2.1.0 Live Streaming Issues
Sat Jan 21, 2017 8:27 am
As of 2.1.0 live streaming no longer works for me. Only tried YouTube and Custom (pointing to YouTube). Both do not work, no connection to YouTube's servers is being established. Tried with OBS, no problems. Anyone else having this issue and have you fixed it?
Re: Action! 2.1.0 Live Streaming Issues
Thu Jan 26, 2017 7:02 am
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Install Action! again. Make sure that your installer file comes from official website - www.mirillis.com (if you have not purchased Action! through Steam).
