Grizz
PC Specification: i7 4790k RX 480 8gb RAM Windows 10
Video is only recorded in 720p 30fps.
Sun Jan 22, 2017 2:01 am
My settings are AVI, Original, 60fps. But it records in 720p 30fps. Is AVI only in 30 fps or is it something else.
Re: Video is only recorded in 720p 30fps.
Thu Jan 26, 2017 7:03 am
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Install Action! again. Make sure that your installer file comes from official website - www.mirillis.com (if you have not purchased Action! through Steam).
