Tristan1978
PC Specification: Quad, ATI Radeon HD 5870, 4 Gb Ram
No sound in MKV
Sat Jul 24, 2010 12:18 pm
Hello all
I tried to play the MKV of Repo Man tonight and for some reason I can not get any sound. The file plays the video perfectly but no sound comes through at all. I get sound on Media PLayer Classic, Windows Media Player, VLC etc. Hopefully the following info re: the audio properties helps:
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 59mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 1.26 GiB (19%)
Is there a codec problem?? Audio is set to 5.1 channels in the options.
Cheers
Tristan
MHB
PC Specification: XP SP3
Re: No sound in MKV
Sat Jul 24, 2010 3:07 pm
Same here.
qwerty
Re: No sound in MKV
Sat Jul 24, 2010 8:50 pm
The problem is mux. I demux using MKVExtractGUI and mux again using MeGUI. New file works fine and hear audio. :)
icsterm
Contact: Yahoo Messenger
Re: No sound in MKV
Sun Jul 25, 2010 7:14 pm
Mirillis should fix this issue because mux/remux is not a normal fix in this situation.
user82
PC Specification: Q6600,Ati HD-4850
Re: No sound in MKV
Sun Jul 25, 2010 10:15 pm
how sad is that!
splash did not stick to the matroska specs and so the new mkvmerge 4.1.x with zlib comrpession makes problems.
SERIOUSLY fix that, i did not expect that poor programming from Mirillis :x
Tristan1978
Re: No sound in MKV
Mon Jul 26, 2010 1:50 am
Well it was definitely annoying but it ended up being an easy fix. I downloaded mkvtoolnix and remuxed the audio with 'no compression' (under advanced tab in audio) and all is good. Thanks for all the help guys. Hopefully Mirillis implements a fix as I have bought the pro version.
crl2007
Re: No sound in MKV
Mon Jul 26, 2010 7:58 am
Same problem here on some videos. We shouldn't fix this by remuxing, they should fix it in their player to accept it as it is and stick to specs.
I now use the trial version and I don't have any plans to buy this software if this issues are not adressed.
Helios
Re: No sound in MKV
Thu Jul 29, 2010 11:03 am
Hi all,
the issue has been fixed and will be resolved in neeres Splash update (comming soon).
Thank you all for very constructive and valuable feedback.
regards,
icsterm
Re: No sound in MKV
Fri Jul 30, 2010 6:52 am
I believe most of the HDMI issues reported also include no sound in some mkv files. Looking forward for the next version :P
ace11
Re: No sound in MKV
Fri Aug 06, 2010 7:47 am
any tip how to bypass this problem for now ? ( until splash update to 1.2)
plz ?
