Jericho2040
PC Specification: i7 950, gtx 970, 12gigas
Problems with record frame drops
Sun Jan 29, 2017 8:08 pm
Good morning everyone,
After the last update I am having problems of very strange frame crashes. The HUD of the program when it is not recording shows that I go to 60 stable frames but when I start to record these fall to 45 - 55 frames.
My computer meets the requirements of both the game (FarCry 4 on ultra) and the requirements of Action !.
I usually did not fall in this game.
What should I do? Wait for them to update and correct the program or try to download a previous version? I have my program registered and completely legal, I need a solution, since I use part of it as a job.
From already thank you very much.
Re: Problems with record frame drops
Tue Jan 31, 2017 7:07 am
Hello, thank you for contacting us. Please report this issue to our technical support via support@mirillis.com They will investigate this issue.
