MusicaGray
PC Specification: Windows 10
[Help] Converting H265 to H264 1080p
Tue Jan 31, 2017 7:59 am
Good day, Ive recently decided to try the top Nvidia Codec in Action!, It seems like the video is extremely high quality of which I am really satisfied about, but I cannot open it in my main video editing software, nor upload it to YouTube.
I decided to try to convert that H265? video to something that my video editor & YouTube can take, I'd like to try to keep as much as the HD as I can of my current video, but then again, my video is useless unless I have it on the right format, Using Splash 2.0, 2 options were given to me, export (Which I hope it stands for convert) my video to either 1080p Main profile / Normal or High quality, or 1080p High profile / Normal or high quality. So I guess my question is this, which of the 2 options would you guys recommend to try to keep as much as the current HD my video has and yet, meet the standard for YouTube uploading / Video editing (Which I believe is H264? 1080p)
Thank you in advance!
Re: [Help] Converting H265 to H264 1080p
Wed Feb 01, 2017 7:35 am
we recommend using High profile with high quality. Also for beter quality you can set higher bitrate.
More about YouTube upload settings you can find here: https://support.google.com/youtube/answer/1722171?hl=en
Return to “Splash 2.0”
