Molda22
PC Specification: Intel Xeon 1231v3, GTX 970, WIN 10 64b
Webcam low FPS in Action (high in other apps)
Sun Feb 05, 2017 9:51 am
i have another problem with webcam and action. The webcam (both in preview and in the actual recording) has very low FPS and i thought that is just how the webcam is, but today i tried the webcam in skype and other programs and the FPS is much much higher and its looking great. Why the webcam is performing much much worse and has a lot lower FPS in Mirillis Action?
Is there a way to fix it?
(its not cause by bad light in the room, i tried skype and action in the same time and webcam in skype was perfectly smooth and in action it is slow as hell with very low FPS)
Please can someone help? thanks
Windows 10
latest drivers
latest Action!
Re: Webcam low FPS in Action (high in other apps)
Tue Feb 07, 2017 7:08 am
Hello, thank you for contacting us. Please report this issue to our technical support via support@mirillis.com They will investigate this issue.
