WagsFTW
PC Specification: i-7 4930K Nvidia GeForce 1060 6GB Win 10
Action! Causing 7 Days to Die game to crash
Sun Feb 05, 2017 4:20 pm
Hello, seems that Action! is causing 7 Days to Die to crash on me. I had filled out a pc bug report on their forums and after they investigated the log files I posted, it was determined that Action! is causing it. This link will take you there. The last 2 posts are the most important. After disabling Action! the game no longer crashes. Can you tell me what if anything I would need to post here/google drive to help you fix the problem? Thank you!
https://7daystodie.com/forums/showthrea ... hing-on-PC
Re: Action! Causing 7 Days to Die game to crash
Tue Feb 07, 2017 7:19 am
thank you for contacting us. Please report this issue to our technical support via support@mirillis.com They will investigate this issue.
