vvassilizaitsevv
PC Specification: 6700k, 980TI, WINDOWS 10 BUILD 1607
Splash 2.0 doesnt work anymore!!
Fri Feb 10, 2017 4:56 pm
When i try to click Splash.exe, it seems to start then 2 sec. later its disappear. No warning No error just disapper.
i, reinstalled it but nothing changed.
formated the system it is same.
Can anybody help me?
Re: Splash 2.0 doesnt work anymore!!
Tue Feb 14, 2017 7:40 am
Please report this issue to our technical support via support@mirillis.com They will investigate this issue.
vvassilizaitsevv
Tue Feb 14, 2017 7:08 pm
Yeah, i already did it...
vvassilizaitsevv
Sat Feb 18, 2017 5:20 pm
The problem has been solved, thx for the technical stuff.
It occured from the new video card driver, i installed the old one then problem gone away...
Dobs
Tue Feb 21, 2017 4:57 pm
So if we want to use Splash we can't update our video drivers?
When is SPLASH going to update their program to work with the video drivers?
sofiabovino
PC Specification: i300,intel,10.0
Tue Feb 06, 2018 12:11 pm
How to make that right which was not mention there
Return to “Splash 2.0”
