Hydreigon18
PC Specification: Windows 10, Intel Core i3, 4 GB Ram.
Lightworks (Video/audio delay)
Mon Feb 13, 2017 2:25 pm
So I've been facing this issue since the beginning of using Action! and the editing program Lightworks and on their forums they say I have a recording problem with not having constant frame rate. In the editing software I put a file in (doesn't matter 2 hours long or 10 minutes long) it starts delaying the audio/video. Help? Should I get another editing software or is there a way to fix it?
Re: Lightworks (Video/audio delay)
Mon Feb 20, 2017 8:49 am
Action! should provides constant frame rate of recordings.
Maybe try another editing software and if problem persists please report this issue to our technical support via support@mirillis.com
Return to “Video editing”
