bruno36
PC Specification: i7 2700k+ radeon r9 280x+ Windows 10
Action Mirillis does not record videos
Tue Feb 14, 2017 8:03 am
Hello! I am confronted with a bug when I record a video part.
The recording of the video during the game goes well, the red Action button is displayed.
The final recorded video has a weight of 0 bytes.
When I return to the windows desktop, the icon in the task bar of Action mirillis is replaced by an R.
The attachment bug2.png is no longer available
The attachment bug1.png is no longer available
Bonjour! Je suis confronté a un bug quand j'enregistre une partie vidéo.
L'enregistrement de la vidéo durant le jeu se passe bien, le bouton de Action rouge est bien affiché.
La vidéo final enregistré a un poid de 0 Octet.
Quand je retourne sur le bureau de windows, L'icone dans la barre des taches de Action mirillis est remplacer par un R.
I7 2700K, Radeon R9 280x, Windows 10 x64
OS: Windows 10 x64
Video Card: Radeon R9 280x
Memory: 8 Go
CPU: I7 2700K
Monitor Resolution: 1920x1080P
Video Type: MP4
bruno36
Re: Action Mirillis does not record videos
Wed Feb 15, 2017 8:41 am
Am I the only one to have this problem? :roll:
OS: Windows 10 x64
Memory: 8 Go
CPU: I7 2700K
Video Type: MP4
Deadly151
PC Specification: Windows 8.1 GTX 750ti
Mon Feb 20, 2017 9:32 am
i have the same problem .......... :(
Tue Feb 21, 2017 7:29 am
there is a chance that one of your audio devices is causing that issue.
To check if it is true please go to Audio Settings tab and disable "Record system sounds" option.
Make a recording a check if it is ok.
Deadly151
Tue Feb 21, 2017 10:50 am
dont work :(
bruno36
Wed Feb 22, 2017 4:32 pm
The problem came from my microphone, thanks
OS: Windows 10 x64
Memory: 8 Go
CPU: I7 2700K
Video Type: MP4
Deadly151
Wed Feb 22, 2017 11:53 pm
how u fix it :( ?
bruno36
Thu Feb 23, 2017 1:36 pm
I plug them into another USB port
OS: Windows 10 x64
Memory: 8 Go
CPU: I7 2700K
Video Type: MP4
Deadly151
Thu Feb 23, 2017 9:16 pm
still not work for me :(
Deadly151
Fri Feb 24, 2017 10:38 am
someone have one more idea ?
