Behtin
PC Specification: Intel i7 920 d0, HD7950, Window 7 x64
Dolby TrueHD Sound Problem...
Sun Dec 18, 2011 9:41 pm
I have Splash Pro EX 1.12.1.0, I just got movie which has Dolby TrueHD Sound. But Splash Pro EX doesn't give me any sound. I tried with MPC, It worked fine. Is there any solition for this? Cause Splash Pro EX is the ultimate HD player, you say, and this sound file is the ultimate HD sound... Where is the problem??
P.J
Re: Dolby TrueHD Sound Problem...
Mon Dec 19, 2011 8:55 pm
Splash doesn't still support Dolby Digital TrueHD :?
Behtin
Wed Dec 21, 2011 4:54 pm
It is biiiiiiiiiiiig weakness.
P.J
Sat Dec 24, 2011 8:29 pm
Right. Hope they add it soon =)
fuvio
PC Specification: Windows 7 Home Premium x64
Mon Dec 26, 2011 1:36 pm
Dolby TrueHD is not ultimate HD sound - maybe one of two ultimate sounds. The most popular and widely used is DTS-HD MA; Dolby TrueHD is in fact losing market share every year. Anyway - Dolby TrueHD sound works for me in SPlashPro EX 1.12.1 even without bitstreaming. Bitstreaming works for all HD audio formats and without bitstreaming only DD+ doesn't work.
lluvia
PC Specification: Intel, NVIDIA, W7
Sun Jan 22, 2012 2:03 pm
Behtin wrote:I have Splash Pro EX 1.12.1.0, I just got movie which has Dolby TrueHD Sound. But Splash Pro EX doesn't give me any sound. I tried with MPC, It worked fine. Is there any solition for this? Cause Splash Pro EX is the ultimate HD player, you say, and this sound file is the ultimate HD sound... Where is the problem??
Splash can support this sound only via bitstreaming or when HD sound included standard ac3 stream. Do you use bitstreaming?
General Forum Support
P.J
Wed Jan 25, 2012 12:13 am
Probably not. We want TrueHD not only by bitstreaming :(
lluvia
Mon Mar 12, 2012 11:46 pm
TrueHD is planned to be supported in BD version.
P.J
Wed Mar 14, 2012 2:06 am
Just tried my first video with TrueHD. It's working:
I can hear the sound :?
Maybe because it has Core, means backward compatible:
Code: Select all
General
Format                           : BDAV
Format/Info                      : Blu-ray Video
File size                        : 896 MiB
Duration                         : 3mn 15s
Overall bit rate                 : 38.5 Mbps
Maximum Overall bit rate         : 48.0 Mbps
Video
Menu ID                          : 1 (0x1)
Format                           : VC-1
Format profile                   : AP@L3
Codec ID                         : 234
Duration                         : 3mn 4s
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Compression mode                 : Lossy
Audio
Menu ID                          : 1 (0x1)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Format profile                   : TrueHD / Core
Mode extension                   : CM (complete main)
Muxing mode                      : Stream extension
Codec ID                         : 131
Duration                         : 3mn 14s
Bit rate mode                    : Variable / Constant
Bit rate                         : Unknown / 640 Kbps
Maximum bit rate                 : 1 818 Kbps / 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Compression mode                 : Lossless / Lossy
astonblake
PC Specification: windows xp
Sun Aug 12, 2012 9:24 pm
Is the sound is clear?
Return to “General Topics”
