Hjalfnar
PC Specification: Windows 10
Mirillis Action not recording, showing black lock symbol
Sun Feb 26, 2017 4:50 am
Hi there! A few days ago Action suddenly didn't want to record properly anymore...right after the update. While the sound is as perfect as always, it suddenly seems to have issues with my multi monitor setup. Its recording of my old 1280x1024 is normal, but if I try to capture anything on my main monitor Action doesn't seem to recognise it properly. It shows a black screen with a lock symbol in 1280x1024, instead of 1980x1080 of my main monitor. Any ideas what's causing this strange issue?
Desktop 26-02-2017 05-45-52-485.jpg (85.64 KiB) Viewed 16442 times
Re: Mirillis Action not recording, showing black lock symbol
Fri Mar 03, 2017 6:52 am
try recording in Active Scren mode and check if it is OK.
Hjalfnar
Wed Mar 08, 2017 10:17 am
That worked for a few days, now Action only records the old monitor. Seriously, I'm loosing it now. I just lost one hour of work again.
Edit: After a lot of cklicking around it now records my main monitor again. Guys, you need to implement a "Choose monitor to record" option in the next patch, really.
bendrajamss
PC Specification: windows 10
Thu Jul 20, 2017 6:46 am
here is the troubleshoot, https://www.youtube.com/watch?v=ye7Guv8eqvk
here is the downloadguide for the Mirillis Action
https://mirillis.com/activation-update-action-tutorials
Fri Jul 21, 2017 5:50 am
Probably you are using "selected application" feature and you trying to record application you haven't selected.
Use "Games and Applications" mode to record games and DirectX applications.
Go to Active Screen mode and change the selected application or turn off this feature.
