Warlinty
PC Specification: AMD A8-5600K, GeForce GTX 750ti Win10
Video speeding up on most applications
Wed Mar 01, 2017 6:16 pm
Action
Action Version: 2.2.1.0
Recording Resolution: 720p (This problem occurs with every resolution)
Recording Mode: Game
Windows and Hardware
OS: Windows 10 Home
Video Card: Gigabyte GTX 750Ti 2x Windforce
Video Driver Version: 378.66
CPU brand and model: AMD A8 5600k @ 3.2GHz
Memory: 8GB
Monitor Resolution: 1920x1080@144Hz
Problem Description
Game/App Problem: Minecraft and most other things
Error Type: Video speeding up
Video Editor: Vegas 14
Description: When I try recording in AVI videos get sped up (No matter the video framerate) by like 1.25x, recording in higher video framerates makes it speed up even faster at times then slow down. I've tried recording with MP4 NVidia NVENC it seems to do it less but the recording and gameplay don't feel as smooth like it's lagging me more.
Re: Video speeding up on most applications
Tue Mar 07, 2017 8:14 am
Please report this to our technical support via support@mirillis.com
Fusion
PC Specification: Windows 7
Sun Mar 12, 2017 5:04 pm
If your videos look something like this does around 1:12 -
https://www.youtube.com/watch?v=hXkHYqMhOVA
I would try lowering allocated memory to the program, limiting FPS (in game), setting priority of Action to high, changing resolution of video to original, trying to keep the fps your getting and the fps you're recording at the same.
The type of video file is also very important. For me using AVI helps with this issue a lot rather than MP4 but if there is an option other than AVI or MP4 (For Example MP4 AMD APP) I suggest using it because it is usually better suited for your GPU.
I used to have this problem with my old computer and it seems to happen when recording a game like Minecraft with a sub par video card and little ram.
Here is a link to my post if you think it might help: http://forum.mirillis.com/viewtopic.php?f=36&t=36770
