gabimx
PC Specification: PENTUM D GFORCE 7100GS
subtitle problem .
Wed Jul 28, 2010 9:20 pm
i have this problem that im playing a movie and i need subtitles for it but the subs are not visible all the time .
thay are Flashing some time for a mili second and thats it .
what can i do to solve the problem ?
p.s
my friend dont have this problem and have the same configurations as me in the software .
thanks in advence ! :)
xw0lf
PC Specification: quad core @ 3.4ghz.... etc
Re: subtitle problem .
Wed Jul 28, 2010 10:22 pm
i think that subtitle module of player need to be polished/improved....
Helios
Thu Jul 29, 2010 11:18 am
Hi gabimx,
1. do you have problem with all files or just the one?
2. does the audio and video plays normally in the problematic file?
3. have you tried to update graphic card drivers?
If all files work wrorng it is rather related to hardware configuration.
regards,
nambit
PC Specification: Windows 7
Subtitles definitely need work.
Thu Jul 29, 2010 7:25 pm
I mentioned this in another thread, but I truly hope more subtitle improvements are on the way. :)
Loving this program so much, but the subtitles need work. My current issues (beefs) are below:
1. Embedded subtitles for files don't autoload, especially for Japanese anime fan-subs.
2. Subtitles often end up garbled. Simultaneous subs (meant for different sections of screen) just mash together.
3. More support for different sub formats would be so nice.
4. Subs often don't stay on the screen long enough (timers are off).
It's such a great product. Worth every penny. If you can get the subtitles fixed, I can ditch MediaPlayer HomeCinema for real. As it stands, I need to use that for a lot of my Japanese anime.
