ToniRG
PC Specification: I7-3820, GTX 970, Windows 8.1 64 bit
Option Capture USB/HDMI in Fullscreen?
Thu Mar 16, 2017 7:05 pm
The option to capture usb / hdmi is great, but it is only displayed in a window and therefore, hdmi capture does not make sense without the option to see it in fullscreen.
Is there any way to view the usb / hdmi capture in fullscreen and not in window?
pemby66
PC Specification: windows 10
Re: Option Capture USB/HDMI in Fullscreen?
Sat Mar 18, 2017 11:20 pm
If you click on the bottom right corner of the window, you can drag it to cover your screen.
Do you know how to record sound as well, as i can't for some reason.
kyleblane
PC Specification: Athlon X4 760K, 16RAM, R7 260x, Win 10
Sun Mar 19, 2017 10:42 pm
Best I've found is that you can stretch the window to be almost full screen.
Can I ask what capture device you're using? My Elgato HD60 isn't showing up in the list on Action and I'm trying to figure it out.
Mon Mar 20, 2017 8:03 am
pemby66 wrote:If you click on the bottom right corner of the window, you can drag it to cover your screen.
You need to choose proper audio device in audio settings.
kyleblane wrote:Best I've found is that you can stretch the window to be almost full screen.
There should be support for Elgato with next release.
