steen
PC Specification: Windows 7 - 64 bit
little box in the upper right corner
Sat Mar 18, 2017 1:01 pm
How can I move the small box that appears in the upper right corner, when I started to record something on my screen.
We like it appears in one of the three others.
The recording time ( Duration) may only be changed using the up and down arrows?
It takes a long time instead of being able to enter it directly via keyboard numbers
Re: little box in the upper right corner
Thu Mar 23, 2017 7:45 am
Use F6 key to hide/show HUD, use F7 key to change its position.
You can change duration using mouse wheel.
Return to “General Topics”
