pemby66
PC Specification: windows 10
New Record Capture Card option.
Sat Mar 18, 2017 11:17 pm
Hello, when trying to record console gameplay withe record application/usb device (capture card) i can only record video without sound.
What do i do because the recordings are perfect. :oops: :? :? :?
Re: New Record Capture Card option.
Fri Mar 24, 2017 7:28 am
make sure you are streaming audio from your device to your PC, for example using line-in port.
Then go to Action! audio settings and select proper audio device from the list.
