Evangelina
PC Specification: AMD Phenom(tm) II X3 710,Geforce 9800 GT
Video recording doesn't work in UT and UT2004 (INVESTIG...)
Mon Dec 19, 2011 6:08 pm
Version: Action! 1.2.0.0 trial
OS: Windows 7 x64 SP1
CPU: AMD Phenom(tm) II X3 710
GFX: NVIDIA GeForce 9800 GT (driver 285.62)
Description: In Unreal Tournament 99 and Unreal tournament 2004 the recorder doesnt work, but in Unreal tournament 3 it works, when i try to record on Ut2004 the FPS counter doesnt show, i have the same problem in UT 99.
Re: Video recording doesn't work in UT and UT2004
Sun Jan 22, 2012 8:10 pm
Thank you for reporting problem.
We are investigating this, in the meantime you can try to run games in windowed mode
and use desktop region to record it.
Do you possibly know what 3d engine this games use (OpenGL or DirectX and which version)?
Evangelina
Re: Video recording doesn't work in UT and UT2004 (INVESTIG.
Sun Jan 22, 2012 8:27 pm
Unreal Tournament 2004 uses Unreal Engine 2.0, and directx 9.0, and the first unreal tournament (99) uses Unreal Engine with directx 7.0
Sun Jan 22, 2012 8:30 pm
Thanks for a feedback.
Action! does not support DX7/DX8.
Games using odl DX version can be recorded only via desktop region when running in windowed mode.
We plan to add support for older engines in the future.
We will investigate UT 2004 as this should work.
Evangelina
Sun Jan 22, 2012 8:33 pm
ok n_n, thank you =)!
