Deniz
PC Specification: Windows 10 Home, i5-2500, Nvidia GTX 660
Game Record Button Disabled After Activation
Thu Mar 23, 2017 2:38 am
I did use Action! 2.3.0.0 as trial. Worked perfect so I bought it.
After Activation the Game Recording Button is DISABLED!
Tried to change almost all Settings back and forth!
Several Reboots!
Uninstallation. Re-Installation.
Nothing! :x
What to do to get this button enabled again?!?!?!
See attached screenshots.
Because it is only allowed to have 256kb per attached file and you can only upload 3 files one screen is missing and i will add that to the replay. Great, huh?
Re: Game Record Button Disabled After Activation
Tue Mar 28, 2017 6:43 am
the recording button is always grayed out in Game/Application mode. You have to start your game or application first to be able to start recording. Please start your game or application. Once you are in your game or application a blue HUD should appear in top right corner (default location). Press F9 (default hotkey) to start recording. You can stop your recording with the same button.
