reverser
PC Specification: win 10,core i7,gtx 960
action problem qith 4k monitor
Wed Apr 26, 2017 9:17 pm
hi
mirilis is rather small and i cant work with it.tried a external manifest file with worked with other softwares.
Code: Select all
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0" xmlns:asmv3="urn:schemas-microsoft-com:asm.v3">
<dependency>
  <dependentAssembly>
    <assemblyIdentity
      type="win32"
      name="Microsoft.Windows.Common-Controls"
      version="6.0.0.0" processorArchitecture="*"
      publicKeyToken="6595b64144ccf1df"
      language="*">
    </assemblyIdentity>
  </dependentAssembly>
</dependency>
<dependency>
  <dependentAssembly>
    <assemblyIdentity
      type="win32"
      name="Microsoft.VC90.CRT"
      version="9.0.21022.8"
      processorArchitecture="amd64"
      publicKeyToken="1fc8b3b9a1e18e3b">
    </assemblyIdentity>
</dependency>
<trustInfo xmlns="urn:schemas-microsoft-com:asm.v3">
  <security>
    <requestedPrivileges>
      <requestedExecutionLevel
        level="asInvoker"
        uiAccess="false"/>
    </requestedPrivileges>
  </security>
</trustInfo>
<asmv3:application>
  <asmv3:windowsSettings xmlns="http://schemas.microsoft.com/SMI/2005/WindowsSettings">
    <ms_windowsSettings:dpiAware xmlns:ms_windowsSettings="http://schemas.microsoft.com/SMI/2005/WindowsSettings">false</ms_windowsSettings:dpiAware>
  </asmv3:windowsSettings>
</asmv3:application>
</assembly>
but app crashes on start.
Brishak
PC Specification: Win 10, I7-4770k, GTX TITAN X
[Resolved] Native 4K Upscaling Programm Window
Sun May 14, 2017 12:06 am
*Update*
The new Update 2.5.1.0 resolves my issue, the Programm Ui can now be set to 100 or 150%. Definitly readable, maybe for some guys with glasses still little bit small. Thanks Team-Mirillis! :)
Hello there Mirillis-Staff,
i´m working and playing on a native 4k resolution Display. My question is, if there is any option to uspcale the Programmwindow, because of it not scaling up...litterly a punch in my eyes to decrypt the small letters xD
Sincerely Your´s
Brishak
Re: [Resolved] Native 4K Upscaling Programm Window
Wed Jul 18, 2018 11:57 am
Problem has been solved in version 2.5.0 and then in 3.1.5
