nickinuhd
PC Specification: Windows 10 Pro 64-Bit, 2x GTX 1080
FPS Drop when Recording
Fri May 19, 2017 12:50 am
I play at a constant 60 FPS at all times on any game and when i start recording i get fps drop down to the 40s and what not and its VERY annoying, i have tried all Hardware Accelerations, intel quick sync, nvidia nvenc etc and nothing works! any possible fix to stop FPS drop when recording?
My PC Specs:
GPU 1: Asus GTX 1080 Founders Edition
GPU 2: PNY GTX 1080 Founders Edition
CPU: Intel Core i7 6700 @ 3.4GHz
RAM: 32 GB DDR4 2400MHz
HDD: Seagate 1 TB
SSD: Kingston 120GB
Mobo: Asus Z170-A
Monitor: Acer XB280HK
OS: Windows 10 Pro 64-Bit
Re: FPS Drop when Recording
Fri May 19, 2017 5:50 am
have you tried recording in AVI?
nickinuhd
Fri May 19, 2017 4:28 pm
Yes i have tried AVI, and i still get fps drop, not only that but the file size is really big and the recording is very laggy.
santtos
PC Specification: 7-4700HQ, nVidia GeForce 770M, Win 8.1
Mon May 22, 2017 9:40 am
I have the same problem.
With Shadow Play I record with 170-180 fps and when I recording with Action I have 90-100 fps when I play Warface.
On Wildlands with Shadow Play I have 60-65 fps with Action 20-30 fps.
On Black OPS III with Shadow Play I have 50-60 fps with Action 25-30 fps.
On Overwatch with Shadow Play I have 120-130 fps with Action 60-70 fps.
Even with OBS I lose some fps but not so much like Action. Is not normal if we think that Shadow Play and OBS are free and Action is commercial.
My specs:
Windows 10, I7 4700HQ, 16Gb DDR3, GTX 770M with 3 GB DDR3, SSD 840 EVO 250GB (SATA-III)
zefirek
PC Specification: Windows 11
Sat Aug 12, 2017 6:45 pm
Same problem here, With ShadowPlay ~5 fps drop and with Action ~15 fps drop.
kingsleytailors
PC Specification: i3 2350, IntelHD3000, W7x64
Tue Oct 31, 2017 6:58 am
Maybe your hardware configuration is slow, unfortunately screen records software need powerful system
tucker8
PC Specification: Windows 7 Ultimate
Wed Nov 29, 2017 9:02 am
I have the same problem. I tried AVI but it didn't work.
gmail sign up
thinfamiliar
Tue Jun 05, 2018 2:20 pm
Fri Aug 03, 2018 6:03 am
If the fps drop is too big then try lowering the recording settings. Lower the fps, quality or bitrate and see if that helps.
nicole-john
PC Specification: 10
Mon Aug 13, 2018 1:54 pm
I have same problem as you.
Contact@cheathacker.com
Return to “General Topics”
