lordbeedoo
PC Specification: Athlon II, Radeon 5500 series, Win 7 64b
Second monitor playback problem
Wed Aug 04, 2010 9:45 pm
I have a problem playing SD videos (divX avi) in full screen on second monitor (connected through DVI). After some time (random - 5 - 20 minutes), video starts to jitter, audio goes fine. It looks like frames were skipped. However, if I move video back to 1st monitor and move back it is corrected, as well as if I rewind the video.
It is not a performance issue, I have new Athlon II, 4 GB DDR 3 and ATi 5500 series. HD video works great as well as hardware acceleration. CPU load goes never over 30 %.
It is not related to Motion2 etc., same thing with and without.
Anyone has an idea what could be a problem and cause extremely annoying snatchy SD video playback ? :?
Thanks for help ...
Re: Second monitor playback problem
Mon Sep 20, 2010 4:22 pm
What is refresh rate on second display. Please make sure it is 59 or 60Hz.
What divx codec do you have installed?
lordbeedoo
Mon Sep 20, 2010 5:29 pm
Ghost wrote:What is refresh rate on second display. Please make sure it is 59 or 60Hz.
Hi, thank you for answer. It is standard LCD TV LG 60 Hz
However, new version PRO 1.2 fixed this issue, whatever it was.
