Carpenter01
PC Specification: i5 750 @4Ghz, R9 280X @1,1Ghz, 8GB DDR3
Operation Flashpoint Red River CRASH (INVESTIGATING)
Thu Dec 22, 2011 11:22 pm
If i want to start the game with Action! running, it freezes after the first loading frame (black screen, but the cursor is from the game, and task manager says it's running. If i disable the overlay with a hotkey the game goes on, but it freezes at the "press enter" screen (black screen again).
Re: Operation Flashpoint Red River CRASH (INVESTIGATING)
Sun Jan 22, 2012 8:17 pm
Can you please check if this will work:
- do not run Action!, close Action! if running.
- run game, go through all menus and start 'real' gameplay
- run Action! and check if it works
Thank you.
Carpenter01
Mon Jan 23, 2012 8:33 pm
Ghost wrote:Can you please check if this will work:
Thank you.
It works that way, even the steam overlay shows up, and runs without any problem.
Sun Feb 26, 2012 9:22 pm
We hoped this problem is fixed but seems to still occur on some PCs.
We will keep investigation and for now we can only advice to use this workaround.
